My Nokia 5 uses a large amount of mobile data
Press Network & Internet.
Press Wi-Fi.
Press Wi-Fi preferences.
Press Advanced.
Press the indicator next to 'Switch to mobile data automatically' to turn the function on or off.
Press Apps & notifications.
Press App notifications.
Press the upper indicator to turn the function on or off.
Press Play Store.
Press Auto-update apps.
To turn off automatic update of apps, press Do not auto-update apps..
To turn on automatic update of apps using mobile network, press Auto-update apps at any time. Data charges may apply..
To turn on automatic update of apps using WiFi, press Auto-update apps over Wi-Fi only..
