Find the opener for the card holder. Insert the opener into the small hole in the SIM holder.
Remove the SIM holder from your phone.
Turn your SIM so the angled corner of the SIM matches the angled corner of the SIM holder.
Place your SIM in the SIM holder and insert the card holder into your phone.
