I have problems using the internet connection on my Nokia 3
Press More.
Press Mobile networks.
Press Access point names.
Press Name.
Press APN.
Press Username.
Key in o2 and press OK.
Press Password.
Key in p and press OK.
Press MCC.
Key in 234 and press OK.
Press MNC.
Key in 10 and press OK.
Press Authentication type.
Press PAP.
Press APN type.
Key in default and press OK.
Press Save.
Press the mobile data icon.
Press the indicator next to 'Mobile data' to turn the function on or off.
Press More.
If you turn on data roaming, press OK.
Press and hold On/Off.
Simultaneously, press and hold the upper part of the Volume key until your phone turns off.
