My Nokia 3.1 uses a large amount of mobile data
Press Network & Internet.
Press Wi-Fi.
Press the indicator next to 'Use Wi-Fi' to turn on the function.
Press Wi-Fi preferences.
Press Advanced.
Press the indicator next to 'Switch to mobile data automatically' to turn the function on or off.
Press Apps & notifications.
Press See all apps.
Press the indicator next to 'Show notifications' to turn the function on or off.
Press Security & location.
Press Location.
Press Advanced.
Press the Return key.
Press App-level permissions.
Press Play Store.
Press Auto-update apps.
Press DONE.
