Press Email address and key in your email address.
Press the field next to 'Require sign-in' to turn on the function.
Press the field next to 'Notify me when email arrives' to turn the function on or off.
Press the field next to 'Sync email from this account' to turn on the function.
Press Account name and key in the required name.
Press Your name and key in the required sender name.
