My Huawei P30 Pro uses a large amount of mobile data
Press Wireless & networks.
Press Data usage.
Press Network access.
Press Wi-Fi.
Press the indicator next to 'Wi-Fi' to turn on the function.
Press Wi-Fi+.
Press the indicator next to 'Wi-Fi+' to turn the function on or off.
Press the indicator next to 'Allow notifications' to turn the function on or off.
Press Play Store.
Press Auto-update apps.
Press DONE.
