I have problems using the internet connection on my Huawei P30 Pro
Press Wireless & networks.
Press Mobile network.
Press Access Point Names (APNs).
Press New APN.
Press Name.
Press APN.
Press Username.
Key in o2 and press OK.
Press Password.
Key in p and press OK.
Press MCC.
Key in 234 and press OK.
Press MNC.
Key in 10 and press OK.
Press Authentication type.
Press PAP.
Press APN type.
Key in default and press OK.
Press the confirm icon.
Press the field next to the required data connection to activate it.
Press Data usage.
Press Network access.
