You have been successfully logged out
Discover extra benefits
Why join O2?
If you've linked your Virgin Media and O2 details to create a new Virgin Media O2 ID, sign in with it here. Find out more
You can uninstall apps to free up memory.
Press Play Store.
Press My apps & games.
Press INSTALLED.
Press UNINSTALL.
Press OK.
