Top queries
Device help
Managing your account
Other ways to get help
Press Sounds & vibration.
Press Phone ringtone.
Press the required ring tones to hear them.
Once you've found a ring tone you like, press arrow left.
To use a different ring tone than the default ones, press Music on device and follow the instructions on the screen to select the required ring tone.
