Top queries
Device help
Managing your account
Other ways to get help
Press the call icon.
Press Calling accounts.
Press the name of the SIM.
Press Call forwarding.
Key in 901 and press Enable.
Press Disable.
Simultaneously, press On/Off and the lower part of the Volume key and keep them both pressed until your phone restarts.
Press More.
Press Call barring.
