I have problems sending and receiving emails on my Honor 200 Pro 5G
Press Users & accounts.
Press Add account.
Press Personal (IMAP).
Press Next.
Press Next.
Press the field below 'Port' and key in 993.
Press SSL/TLS.
Press Next.
Press the field below 'Port' and key in 587.
Press SSL/TLS.
Press Next.
Press Next.
Press Your name and key in the required sender name.
Press Next.
