I have problems using the internet connection on my Honor 200 Pro 5G
Press Mobile network.
Press Mobile data.
Press Access Point Names (APNs).
Press New APN.
Press Name.
Press APN.
Press Username.
Key in o2 and press OK.
Press Password.
Key in p and press OK.
Press MCC.
Key in 234 and press OK.
Press MNC.
Key in 10 and press OK.
Press Authentication type.
Press PAP.
Press APN type.
Key in default and press OK.
Press the save icon.
Press Data usage.
Press Network access.
Press the field in the "Mobile data" column next to the required app to turn the function on or off.
Press Mobile data.
Simultaneously, press On/Off and the lower part of the Volume key and keep them both pressed until your phone restarts.
