My Honor 200 5G uses a large amount of mobile data
Press Mobile network.
Press Data usage.
Press Network access.
Press the field in the "Mobile data" column next to the required app to turn the function on or off.
Press Wi-Fi.
Press the indicator next to 'Wi-Fi' to turn on the function.
Press More settings.
Press Wi-Fi+.
Press the indicator next to 'Wi-Fi+' to turn the function on or off.
Press Notifications & status bar.
Press Manage all.
Press Location.
Press Location.
Press arrow left twice.
Press Location Accuracy.
Press Play Store.
Press the profile icon.
Press Network preferences.
Press Auto-update apps.
To turn on automatic update of apps using mobile network, press Update all apps over Wi-Fi or mobile data.
To turn on limited update of apps using mobile network, press Update with limited amount of mobile data.
If you turn on limited update of apps via mobile network, your most used apps are automatically updated via the mobile network when no WiFi networks are within range.
To turn on automatic update of apps using WiFi, press Update over Wi-Fi only.
