You can use your smartwatch for navigation helping you find a certain destination.
Press the Google Maps icon.
Press the microphone icon and say the required destination.
Press the confirm icon.
Press the keypad icon.
Key in the required destination and press the search icon.
Press the required mode of transportation.
Follow the instructions on the screen to navigate to the selected destination.
Press the map icon to see the route on a map.
Press the route description icon to return to the directions.
Press Exit.
Press the crown to return to the home screen.
