You can use your smartwatch for navigation helping you find a certain destination.
Press the crown.
Press Maps.
Press the microphone icon and say the required destination.
Press the search icon.
Press the keypad icon.
Key in the required destination and press the search icon.
Press the required mode of transportation.
Follow the instructions on the screen to navigate to the selected destination.
Press the map icon.
Press the directions icon.
Press Exit.
Press the crown to return to the home screen.
