The battery life on my Google Pixel Fold is short
Press Passwords and accounts.
Press the indicator next to 'Automatically sync app data' to turn the function on or off.
Press OK.
Press Play Store.
Press the profile icon.
Press Network preferences.
Press Auto-update apps.
Press OK.
Press App notifications.
Press the drop down list.
Press the indicator next to the required apps to turn the function on or off.
Press Internet.
Press Done.
Press Battery.
Press Battery Saver.
Press the required settings to turn them on or off.
Press the indicator next to 'Use Battery Saver' to turn on the function.
To end one running application, slide your finger upwards on the required application.
To end all running applications, slide you finger right on the screen.
Press Clear all.
Press Location.
Press App location permissions.
Press arrow left twice.
Press Location Services.
