Press Sound and vibration.
Press Phone ringtone.
Press the required category.
Press the required ringtones to hear them.
Once you've found a ringtone you like, press SAVE.
To use a different ringtone than the default ones, press My Sounds and follow the instructions on the screen to select the required ringtone.
