The battery life on my Google Pixel 9 is short
Press Passwords, passkeys and autofill.
Press the indicator next to 'Automatically sync app data' to turn the function on or off.
Press OK.
Press Play Store.
Press the profile icon.
Press Network preferences.
Press Auto-update apps.
To turn on automatic update of apps using mobile network, press Update all apps over Wi-Fi or mobile data.
To turn on limited update of apps using mobile network, press Update with limited amount of mobile data.
If you turn on limited update of apps via mobile network, your most used apps are automatically updated via the mobile network when no WiFi networks are within range.
To turn on automatic update of apps using WiFi, press Update over Wi-Fi only.
Press App notifications.
Press the drop down list.
Press the indicator next to the required apps to turn the function on or off.
Press the network icon.
Press the indicator next to the mobile data icon to turn the function on or off.
Press Done.
Press Battery.
Press Battery Saver.
Press the required settings to turn them on or off.
Press the indicator next to 'Use Battery Saver' to turn on the function.
To end one running application, slide your finger upwards on the required application.
To end all running applications, slide you finger right on the screen.
Press Clear all.
Press Location.
Press App location permissions.
Press arrow left twice.
Press Location Services.
