My Google Pixel 8 Pro uses a large amount of mobile data
Press App notifications.
Press the drop down list.
Press the indicator next to the required apps to turn the function on or off.
Press Location.
Press App location permissions.
Press arrow left twice.
Press Location Services.
Press Play Store.
Press the profile icon.
Press Network preferences.
Press Auto-update apps.
Press OK.
