I have problems using the internet connection on my Google Pixel 8 Pro
Press Network and Internet.
Press SIMs.
Press the name of the SIM.
Press Access point names.
Press Name.
Press APN.
Press Username.
Key in o2 and press OK.
Press Password.
Key in p and press OK.
Press MCC.
Key in 234 and press OK.
Press MNC.
Key in 10 and press OK.
Press Authentication type.
Press PAP.
Press APN type.
Key in default and press OK.
Press Save.
Press Internet.
Press Done.
Press SIMs.
Press and hold the Side key for about 30 seconds to restart your phone.
