I have problems sending and receiving emails on my Google Pixel 8
Press Passwords and accounts.
Press Add account.
Press Personal (IMAP).
Press NEXT.
Press NEXT.
Press the field below 'Port' and key in 993.
Press SSL/TLS.
Press NEXT.
Press the field below 'Port' and key in 587.
Press SSL/TLS.
Press NEXT.
Press NEXT.
Press NEXT.
