My Google Pixel 7 uses a large amount of mobile data
Press Apps.
Press See all apps.
Press the indicator next to 'All notifications' to turn the function on or off.
Press Location.
Press App location permissions.
Press arrow left twice.
Press Location Services.
Press Play Store.
Press the profile icon.
Press Network preferences .
Press Auto-update apps.
Press DONE.
