The battery life on my Google Pixel 7 is short
Press Passwords and accounts.
Press the indicator next to 'Automatically sync app data' to turn the function on or off.
Press OK.
Press Play Store.
Press the profile icon.
Press Network preferences .
Press Auto-update apps.
Press DONE.
Press Apps.
Press See all apps.
Press the indicator next to 'All notifications' to turn the function on or off.
Press Network and Internet.
Press Internet.
Press the indicator next to 'Mobile data' to turn the function on or off.
Press Battery Saver to turn on the function.
To end one running application, slide your finger upwards on the required application.
To end all running applications, slide you finger right from the left side of the screen.
Press Clear all.
Press Location.
Press App location permissions.
Press arrow left twice.
Press Location Services.
