Press Sound and vibration.
Press Phone ringtone.
Press the required category.
Press the add ring tone icon and go to the required folder.
Press the required ring tone to add it to the list of ring tones.
Press the required ring tones to hear them.
Once you've found a ring tone you like, press SAVE.
