I have problems sending and receiving emails on my Google Pixel 4a 5G
Press Accounts.
Press Add account.
Press Personal (POP3).
Press NEXT.
Press NEXT.
Press the drop down list below 'Delete emails from server'.
Press When I delete from Inbox to delete emails on the server when you delete them on your phone.
Press NEXT.
Press NEXT.
Press NEXT.
Press NEXT.
Press Gmail.
Press the email account icon.
Press Compose.
Press the required contact.
Press the attachment icon.
Press Attach file and go to the required folder.
Press the required file.
Press Accounts.
Press Add account.
Press Personal (IMAP).
Press NEXT.
Press NEXT.
Press NEXT.
Press NEXT.
Press NEXT.
Press Your name and key in the required sender name.
Press NEXT.
