I have problems using the internet connection on my Google Pixel 4a 5G
Press Network and Internet.
Press Mobile network.
Press Advanced.
Press Access point names.
Press New APN.
Press Name.
Press APN.
Press Username.
Key in o2 and press OK.
Press Password.
Key in p and press OK.
Press MCC.
Key in 234 and press OK.
Press MNC.
Key in 10 and press OK.
Press Authentication type.
Press PAP.
Press APN type.
Key in default and press OK.
Press Save.
Press the field next to the required data connection to activate it.
Press and hold On/Off.
