How to set up voicemail on your Doro 6620
To receive voice messages, you need to divert your calls to your voicemail. To divert calls to your voicemail, you need to save the voicemail number.
Check out nowTo receive voice messages, you need to divert your calls to your voicemail. To divert calls to your voicemail, you need to save the voicemail number.
