The battery life on my Apple iPhone 16 Pro Max is short
![](https://cdn.sp-selfservice.com/ml/230125-f-4bde18cd-e160-4c52-9d28-fbbd829095ca.png?width=360&height=782)
![](https://cdn.sp-selfservice.com/ml/230125-f-4bde18cd-e160-4c52-9d28-fbbd829095ca.png?width=226&height=490)
![](https://cdn.sp-selfservice.com/ml/230125-f-5b32e6da-551c-40ed-8c1c-b468990aceab.png?width=360&height=782)
![](https://cdn.sp-selfservice.com/ml/230125-f-5b32e6da-551c-40ed-8c1c-b468990aceab.png?width=226&height=490)
Press App Store.
![](https://cdn.sp-selfservice.com/ml/230125-f-0f844711-7444-409b-8685-4763a6a6526e.png?width=360&height=782)
![](https://cdn.sp-selfservice.com/ml/230125-f-0f844711-7444-409b-8685-4763a6a6526e.png?width=226&height=490)
Press App Store.
![](https://cdn.sp-selfservice.com/ml/230125-f-3dd13814-a9e1-4f57-8253-ae471db4b2fa.png?width=360&height=782)
![](https://cdn.sp-selfservice.com/ml/230125-f-3dd13814-a9e1-4f57-8253-ae471db4b2fa.png?width=226&height=490)
![](https://cdn.sp-selfservice.com/ml/230125-f-090e31a9-4d38-4468-a2e8-56c27b9cd3cf.png?width=360&height=782)
![](https://cdn.sp-selfservice.com/ml/230125-f-090e31a9-4d38-4468-a2e8-56c27b9cd3cf.png?width=226&height=490)
Press Scheduled Summary.
![](https://cdn.sp-selfservice.com/ml/230125-f-dc5c8683-052f-4012-aec7-399373469735.png?width=360&height=782)
![](https://cdn.sp-selfservice.com/ml/230125-f-dc5c8683-052f-4012-aec7-399373469735.png?width=226&height=490)
Press Show Previews.
![](https://cdn.sp-selfservice.com/ml/230125-f-a25cca4a-d979-44bb-9d76-0d5741500f2b.png?width=360&height=782)
![](https://cdn.sp-selfservice.com/ml/230125-f-a25cca4a-d979-44bb-9d76-0d5741500f2b.png?width=226&height=490)
Press Screen Sharing.
![](https://cdn.sp-selfservice.com/ml/230125-f-d1d7f627-cdfd-4b4d-bc12-38ffe8575b7c.png?width=360&height=782)
![](https://cdn.sp-selfservice.com/ml/230125-f-d1d7f627-cdfd-4b4d-bc12-38ffe8575b7c.png?width=226&height=490)
![](https://cdn.sp-selfservice.com/ml/230125-f-f413d366-e169-4fdc-a9f2-98c2fa8d58d6.png?width=360&height=782)
![](https://cdn.sp-selfservice.com/ml/230125-f-f413d366-e169-4fdc-a9f2-98c2fa8d58d6.png?width=226&height=490)
Press Notification Grouping.
![](https://cdn.sp-selfservice.com/ml/230125-f-d93c0cb3-9ce0-4f79-bbad-0b00ad412261.png?width=360&height=782)
![](https://cdn.sp-selfservice.com/ml/230125-f-d93c0cb3-9ce0-4f79-bbad-0b00ad412261.png?width=226&height=490)
![](https://cdn.sp-selfservice.com/ml/230125-f-e6bfec5e-5dbd-4942-82fc-fbf8f0bed8de.png?width=360&height=782)
![](https://cdn.sp-selfservice.com/ml/230125-f-e6bfec5e-5dbd-4942-82fc-fbf8f0bed8de.png?width=226&height=490)
![](https://cdn.sp-selfservice.com/ml/230125-f-205d8c16-de53-4eca-8eb6-7228ba6168f2.png?width=360&height=782)
![](https://cdn.sp-selfservice.com/ml/230125-f-205d8c16-de53-4eca-8eb6-7228ba6168f2.png?width=226&height=490)
![](https://cdn.sp-selfservice.com/ml/230125-f-fbf91fb0-0d92-40c4-8fe1-ddd2cdec9e2e.png?width=360&height=782)
![](https://cdn.sp-selfservice.com/ml/230125-f-fbf91fb0-0d92-40c4-8fe1-ddd2cdec9e2e.png?width=226&height=490)
Press Mobile Service.
![](https://cdn.sp-selfservice.com/ml/230125-f-73411d32-6674-4461-9eb6-cc69c58a1ff4.png?width=360&height=782)
![](https://cdn.sp-selfservice.com/ml/230125-f-73411d32-6674-4461-9eb6-cc69c58a1ff4.png?width=226&height=490)
![](https://cdn.sp-selfservice.com/ml/230125-f-b0efa291-7e02-447c-ac6a-980c1c9d9ff6.png?width=360&height=782)
![](https://cdn.sp-selfservice.com/ml/230125-f-b0efa291-7e02-447c-ac6a-980c1c9d9ff6.png?width=226&height=490)
Press Battery.
![](https://cdn.sp-selfservice.com/ml/230125-f-b495df32-2f38-4cff-9d6a-b2e970d24491.png?width=360&height=782)
![](https://cdn.sp-selfservice.com/ml/230125-f-b495df32-2f38-4cff-9d6a-b2e970d24491.png?width=226&height=490)
![](https://cdn.sp-selfservice.com/ml/230125-f-7f64110d-c837-435d-989f-0dd13578ffa9.png?width=360&height=782)
![](https://cdn.sp-selfservice.com/ml/230125-f-7f64110d-c837-435d-989f-0dd13578ffa9.png?width=226&height=490)
Press General.
![](https://cdn.sp-selfservice.com/ml/230125-f-29a443ad-342b-4b3c-ac5a-30fe6e3b84c1.png?width=360&height=782)
![](https://cdn.sp-selfservice.com/ml/230125-f-29a443ad-342b-4b3c-ac5a-30fe6e3b84c1.png?width=226&height=490)
Press Background App Refresh.
![](https://cdn.sp-selfservice.com/ml/230125-f-63bef6ce-6991-4d95-9111-1130c56f519b.png?width=360&height=782)
![](https://cdn.sp-selfservice.com/ml/230125-f-63bef6ce-6991-4d95-9111-1130c56f519b.png?width=226&height=490)
![](https://cdn.sp-selfservice.com/ml/230125-f-927dbe25-7a49-45e6-8e05-cd349ba56686.png?width=360&height=782)
![](https://cdn.sp-selfservice.com/ml/230125-f-927dbe25-7a49-45e6-8e05-cd349ba56686.png?width=226&height=490)
![](https://cdn.sp-selfservice.com/ml/230125-f-827e412e-92f0-4bf4-bcf1-2161c07fed82.png?width=360&height=782)
![](https://cdn.sp-selfservice.com/ml/230125-f-827e412e-92f0-4bf4-bcf1-2161c07fed82.png?width=226&height=490)
Press Privacy & Security.
![](https://cdn.sp-selfservice.com/ml/230125-f-339bbb47-2c75-4464-ae88-d2c06d384025.png?width=360&height=782)
![](https://cdn.sp-selfservice.com/ml/230125-f-339bbb47-2c75-4464-ae88-d2c06d384025.png?width=226&height=490)
Press Location Services.
![](https://cdn.sp-selfservice.com/ml/230125-f-f247c941-c4e2-4461-847c-08e96164be9b.png?width=360&height=782)
![](https://cdn.sp-selfservice.com/ml/230125-f-f247c941-c4e2-4461-847c-08e96164be9b.png?width=226&height=490)
![](https://cdn.sp-selfservice.com/ml/230125-f-0ee7951d-f55e-4f60-9352-1abcbcb5028c.png?width=360&height=782)
![](https://cdn.sp-selfservice.com/ml/230125-f-0ee7951d-f55e-4f60-9352-1abcbcb5028c.png?width=226&height=490)
![](https://cdn.sp-selfservice.com/ml/230125-f-7c0f9642-872b-41c7-accc-fee635f74425.png?width=360&height=782)
![](https://cdn.sp-selfservice.com/ml/230125-f-7c0f9642-872b-41c7-accc-fee635f74425.png?width=226&height=490)
![loader](/help/phones-sims-and-devices/_nuxt/loader.BU3jhCRe.gif)
