My Apple iPhone 15 Pro Max uses a large amount of mobile data
![](https://cdn.sp-selfservice.com/ml/121124-f-f44299dc-4f7a-4300-9782-d4e0bd965755.png?width=356&height=768)
![](https://cdn.sp-selfservice.com/ml/121124-f-f44299dc-4f7a-4300-9782-d4e0bd965755.png?width=222&height=480)
![](https://cdn.sp-selfservice.com/ml/121124-f-528c9a6f-b19b-401d-a478-5c23e4e01507.png?width=356&height=768)
![](https://cdn.sp-selfservice.com/ml/121124-f-528c9a6f-b19b-401d-a478-5c23e4e01507.png?width=222&height=480)
Press App Store.
![](https://cdn.sp-selfservice.com/ml/121124-f-4484b06e-c94e-49b1-bc80-4ab1ca6ddcc5.png?width=356&height=768)
![](https://cdn.sp-selfservice.com/ml/121124-f-4484b06e-c94e-49b1-bc80-4ab1ca6ddcc5.png?width=222&height=480)
![](https://cdn.sp-selfservice.com/ml/121124-f-f65d0f07-b716-44a4-b09c-b5af5e7cd0ae.png?width=356&height=768)
![](https://cdn.sp-selfservice.com/ml/121124-f-f65d0f07-b716-44a4-b09c-b5af5e7cd0ae.png?width=222&height=480)
Press Mobile Service.
![](https://cdn.sp-selfservice.com/ml/121124-f-db435c30-31b3-462f-b32d-efe009dfe30c.png?width=356&height=768)
![](https://cdn.sp-selfservice.com/ml/121124-f-db435c30-31b3-462f-b32d-efe009dfe30c.png?width=222&height=480)
Press Mobile Data Options.
![](https://cdn.sp-selfservice.com/ml/121124-f-8f69a92b-2886-4791-ac6e-198d268fc5c5.png?width=356&height=768)
![](https://cdn.sp-selfservice.com/ml/121124-f-8f69a92b-2886-4791-ac6e-198d268fc5c5.png?width=222&height=480)
Press Data Mode.
![](https://cdn.sp-selfservice.com/ml/121124-f-91528058-2b52-43a9-b49f-f01e64388276.png?width=356&height=768)
![](https://cdn.sp-selfservice.com/ml/121124-f-91528058-2b52-43a9-b49f-f01e64388276.png?width=222&height=480)
![](https://cdn.sp-selfservice.com/ml/121124-f-d0eb4e57-ea2d-415d-8a9d-8fad05179dd2.png?width=356&height=768)
![](https://cdn.sp-selfservice.com/ml/121124-f-d0eb4e57-ea2d-415d-8a9d-8fad05179dd2.png?width=222&height=480)
![](https://cdn.sp-selfservice.com/ml/121124-f-2fa43d66-2ba5-4f13-ad09-8d47b7725aab.png?width=356&height=768)
![](https://cdn.sp-selfservice.com/ml/121124-f-2fa43d66-2ba5-4f13-ad09-8d47b7725aab.png?width=222&height=480)
![](https://cdn.sp-selfservice.com/ml/121124-f-48a7f5a6-5672-40a5-8c61-b4e755ae5020.png?width=356&height=768)
![](https://cdn.sp-selfservice.com/ml/121124-f-48a7f5a6-5672-40a5-8c61-b4e755ae5020.png?width=222&height=480)
Press Scheduled Summary.
![](https://cdn.sp-selfservice.com/ml/121124-f-6c1d64a6-4a8a-4b08-aebc-a94d0f6d124d.png?width=356&height=768)
![](https://cdn.sp-selfservice.com/ml/121124-f-6c1d64a6-4a8a-4b08-aebc-a94d0f6d124d.png?width=222&height=480)
Press Show Previews.
![](https://cdn.sp-selfservice.com/ml/121124-f-b0aed9df-0862-42ea-8703-226db4929823.png?width=356&height=768)
![](https://cdn.sp-selfservice.com/ml/121124-f-b0aed9df-0862-42ea-8703-226db4929823.png?width=222&height=480)
Press Screen Sharing.
![](https://cdn.sp-selfservice.com/ml/121124-f-ada9c97b-1166-497c-af10-b31c14c97c67.png?width=356&height=768)
![](https://cdn.sp-selfservice.com/ml/121124-f-ada9c97b-1166-497c-af10-b31c14c97c67.png?width=222&height=480)
![](https://cdn.sp-selfservice.com/ml/121124-f-deb2e635-468a-4b6d-8263-35b0e7149383.png?width=356&height=768)
![](https://cdn.sp-selfservice.com/ml/121124-f-deb2e635-468a-4b6d-8263-35b0e7149383.png?width=222&height=480)
Press Notification Grouping.
![](https://cdn.sp-selfservice.com/ml/121124-f-b61b15f1-87b7-4ba5-9960-4fb99f862953.png?width=356&height=768)
![](https://cdn.sp-selfservice.com/ml/121124-f-b61b15f1-87b7-4ba5-9960-4fb99f862953.png?width=222&height=480)
![](https://cdn.sp-selfservice.com/ml/121124-f-4f46cab8-43e1-4d08-8a7b-5f860daff00b.png?width=356&height=768)
![](https://cdn.sp-selfservice.com/ml/121124-f-4f46cab8-43e1-4d08-8a7b-5f860daff00b.png?width=222&height=480)
![](https://cdn.sp-selfservice.com/ml/121124-f-9684c8df-b713-4bc0-92d6-dbf6f1029c76.png?width=356&height=768)
![](https://cdn.sp-selfservice.com/ml/121124-f-9684c8df-b713-4bc0-92d6-dbf6f1029c76.png?width=222&height=480)
Press General.
![](https://cdn.sp-selfservice.com/ml/121124-f-99edbbb3-a6a9-45eb-98bf-a3ba847f51af.png?width=356&height=768)
![](https://cdn.sp-selfservice.com/ml/121124-f-99edbbb3-a6a9-45eb-98bf-a3ba847f51af.png?width=222&height=480)
Press Background App Refresh.
![](https://cdn.sp-selfservice.com/ml/121124-f-d291820c-8cf9-4099-a44a-26dba76a2982.png?width=356&height=768)
![](https://cdn.sp-selfservice.com/ml/121124-f-d291820c-8cf9-4099-a44a-26dba76a2982.png?width=222&height=480)
![](https://cdn.sp-selfservice.com/ml/121124-f-d7429f03-8faa-4291-889d-c724543ec803.png?width=356&height=768)
![](https://cdn.sp-selfservice.com/ml/121124-f-d7429f03-8faa-4291-889d-c724543ec803.png?width=222&height=480)
Press Privacy & Security.
![](https://cdn.sp-selfservice.com/ml/121124-f-d1a843d7-6b7c-437c-95ac-0f586070523c.png?width=356&height=768)
![](https://cdn.sp-selfservice.com/ml/121124-f-d1a843d7-6b7c-437c-95ac-0f586070523c.png?width=222&height=480)
Press Location Services.
![](https://cdn.sp-selfservice.com/ml/121124-f-f1468a44-b468-4831-b974-978a17414a6e.png?width=356&height=768)
![](https://cdn.sp-selfservice.com/ml/121124-f-f1468a44-b468-4831-b974-978a17414a6e.png?width=222&height=480)
![](https://cdn.sp-selfservice.com/ml/121124-f-6d3c8544-b28c-4406-b48e-bce8bc7030ee.png?width=356&height=768)
![](https://cdn.sp-selfservice.com/ml/121124-f-6d3c8544-b28c-4406-b48e-bce8bc7030ee.png?width=222&height=480)
![](https://cdn.sp-selfservice.com/ml/121124-f-40ea3e9a-6502-47f5-a4a5-dc36bc619e56.png?width=356&height=768)
![](https://cdn.sp-selfservice.com/ml/121124-f-40ea3e9a-6502-47f5-a4a5-dc36bc619e56.png?width=222&height=480)
![loader](/help/phones-sims-and-devices/_nuxt/loader.BU3jhCRe.gif)
