Ready to check out?
Check out now
How to turn airplane mode on your Apple iPhone 14 Pro Max on or off
You can turn off all wireless connections so your phone can’t cause any interference with sensitive equipment in a plane or a hospital. You can use many phone functions when airplane mode is turned on, but you can't send messages or make calls.
