How to select lock screen settings on your Apple iPhone 14 Pro
Press Add.
Press Focus.
Press the close icon.
Press the delete icon.
Press Delete This Wallpaper.
Press Display & Brightness.
Press the indicator next to 'Always On' to turn the function on or off.
You can dim the lock screen on your phone and still have all your content displayed, e.g. background image, clock and widgets.
