My Apple iPhone 13 Pro uses a large amount of mobile data
Press App Store.
Press Mobile Service.
Press Mobile Data Options.
Press Data Mode.
Press Scheduled Summary.
Press Show Previews.
Press Screen Sharing.
Press Notification Grouping.
Press General.
Press Background App Refresh.
Press Privacy & Security.
Press Location Services.
