The battery life on my Apple iPhone 13 Pro is short
![](https://cdn.sp-selfservice.com/ml/271124-f-dcd12cb7-4bc3-4d61-92a5-7937d5eb45b5.png?width=354&height=766)
![](https://cdn.sp-selfservice.com/ml/271124-f-dcd12cb7-4bc3-4d61-92a5-7937d5eb45b5.png?width=222&height=478)
![](https://cdn.sp-selfservice.com/ml/271124-f-1c5b6712-fc07-4e32-acac-713715836213.png?width=354&height=766)
![](https://cdn.sp-selfservice.com/ml/271124-f-1c5b6712-fc07-4e32-acac-713715836213.png?width=222&height=478)
Press App Store.
![](https://cdn.sp-selfservice.com/ml/271124-f-e7c1313f-bacd-47f9-b758-4bfb8cfca140.png?width=354&height=766)
![](https://cdn.sp-selfservice.com/ml/271124-f-e7c1313f-bacd-47f9-b758-4bfb8cfca140.png?width=222&height=478)
Press App Store.
![](https://cdn.sp-selfservice.com/ml/271124-f-10e20e0a-f70e-4f55-b032-0e0707291eba.png?width=354&height=766)
![](https://cdn.sp-selfservice.com/ml/271124-f-10e20e0a-f70e-4f55-b032-0e0707291eba.png?width=222&height=478)
![](https://cdn.sp-selfservice.com/ml/271124-f-8cec074e-ebf0-461b-94b1-0ddf11ccdf70.png?width=354&height=766)
![](https://cdn.sp-selfservice.com/ml/271124-f-8cec074e-ebf0-461b-94b1-0ddf11ccdf70.png?width=222&height=478)
Press Scheduled Summary.
![](https://cdn.sp-selfservice.com/ml/271124-f-2afe9cff-073d-4f4d-a69b-4b2365931972.png?width=354&height=766)
![](https://cdn.sp-selfservice.com/ml/271124-f-2afe9cff-073d-4f4d-a69b-4b2365931972.png?width=222&height=478)
Press Show Previews.
![](https://cdn.sp-selfservice.com/ml/271124-f-eaeb2eae-862a-496b-9f79-0acfca452f03.png?width=354&height=766)
![](https://cdn.sp-selfservice.com/ml/271124-f-eaeb2eae-862a-496b-9f79-0acfca452f03.png?width=222&height=478)
Press Screen Sharing.
![](https://cdn.sp-selfservice.com/ml/271124-f-73fa372e-cb72-4f3b-b104-7540f8289db3.png?width=354&height=766)
![](https://cdn.sp-selfservice.com/ml/271124-f-73fa372e-cb72-4f3b-b104-7540f8289db3.png?width=222&height=478)
![](https://cdn.sp-selfservice.com/ml/271124-f-ba78d250-7d88-48cf-8cd5-29e91422b15a.png?width=354&height=766)
![](https://cdn.sp-selfservice.com/ml/271124-f-ba78d250-7d88-48cf-8cd5-29e91422b15a.png?width=222&height=478)
Press Notification Grouping.
![](https://cdn.sp-selfservice.com/ml/271124-f-874699ff-b157-42da-bf0a-6fe3bc3e5022.png?width=354&height=766)
![](https://cdn.sp-selfservice.com/ml/271124-f-874699ff-b157-42da-bf0a-6fe3bc3e5022.png?width=222&height=478)
![](https://cdn.sp-selfservice.com/ml/271124-f-969c2467-c8b8-49de-8b78-dc629f97ba06.png?width=354&height=766)
![](https://cdn.sp-selfservice.com/ml/271124-f-969c2467-c8b8-49de-8b78-dc629f97ba06.png?width=222&height=478)
![](https://cdn.sp-selfservice.com/ml/271124-f-29d7e526-773c-4f0c-9013-2cca8353458f.png?width=354&height=766)
![](https://cdn.sp-selfservice.com/ml/271124-f-29d7e526-773c-4f0c-9013-2cca8353458f.png?width=222&height=478)
![](https://cdn.sp-selfservice.com/ml/271124-f-99e1eb26-959e-4731-a79b-ec642aacc704.png?width=354&height=766)
![](https://cdn.sp-selfservice.com/ml/271124-f-99e1eb26-959e-4731-a79b-ec642aacc704.png?width=222&height=478)
Press Mobile Service.
![](https://cdn.sp-selfservice.com/ml/271124-f-8d4c76c1-0c2e-476f-821d-c26b1bd9a7cb.png?width=354&height=766)
![](https://cdn.sp-selfservice.com/ml/271124-f-8d4c76c1-0c2e-476f-821d-c26b1bd9a7cb.png?width=222&height=478)
![](https://cdn.sp-selfservice.com/ml/271124-f-5571b725-9486-4d88-9967-60b7931995ae.png?width=354&height=766)
![](https://cdn.sp-selfservice.com/ml/271124-f-5571b725-9486-4d88-9967-60b7931995ae.png?width=222&height=478)
Press Battery.
![](https://cdn.sp-selfservice.com/ml/271124-f-8868318c-1cd9-47b2-b6b3-b0c9aa768d65.png?width=354&height=766)
![](https://cdn.sp-selfservice.com/ml/271124-f-8868318c-1cd9-47b2-b6b3-b0c9aa768d65.png?width=222&height=478)
![](https://cdn.sp-selfservice.com/ml/271124-f-6a4d765b-ae94-41ec-8560-f511dfdcc76a.png?width=354&height=766)
![](https://cdn.sp-selfservice.com/ml/271124-f-6a4d765b-ae94-41ec-8560-f511dfdcc76a.png?width=222&height=478)
Press General.
![](https://cdn.sp-selfservice.com/ml/271124-f-4628ca13-4a25-40b8-b949-69e9ee870761.png?width=354&height=766)
![](https://cdn.sp-selfservice.com/ml/271124-f-4628ca13-4a25-40b8-b949-69e9ee870761.png?width=222&height=478)
Press Background App Refresh.
![](https://cdn.sp-selfservice.com/ml/271124-f-4a4ea147-9a72-443e-9660-7738618b5c34.png?width=354&height=766)
![](https://cdn.sp-selfservice.com/ml/271124-f-4a4ea147-9a72-443e-9660-7738618b5c34.png?width=222&height=478)
![](https://cdn.sp-selfservice.com/ml/271124-f-5eea456b-9974-4748-96bc-30990075da7f.png?width=354&height=766)
![](https://cdn.sp-selfservice.com/ml/271124-f-5eea456b-9974-4748-96bc-30990075da7f.png?width=222&height=478)
![](https://cdn.sp-selfservice.com/ml/271124-f-d1d4480f-9b11-4ae1-a9ab-8d2696be9f17.png?width=354&height=766)
![](https://cdn.sp-selfservice.com/ml/271124-f-d1d4480f-9b11-4ae1-a9ab-8d2696be9f17.png?width=222&height=478)
Press Privacy & Security.
![](https://cdn.sp-selfservice.com/ml/271124-f-cc7d9755-7126-4605-999c-994e57ea50e3.png?width=354&height=766)
![](https://cdn.sp-selfservice.com/ml/271124-f-cc7d9755-7126-4605-999c-994e57ea50e3.png?width=222&height=478)
Press Location Services.
![](https://cdn.sp-selfservice.com/ml/271124-f-3efb5186-a562-40d7-8d98-0604a690669b.png?width=354&height=766)
![](https://cdn.sp-selfservice.com/ml/271124-f-3efb5186-a562-40d7-8d98-0604a690669b.png?width=222&height=478)
![](https://cdn.sp-selfservice.com/ml/271124-f-c1b19f7c-ff91-4c1d-803c-a50df5e11fa0.png?width=354&height=766)
![](https://cdn.sp-selfservice.com/ml/271124-f-c1b19f7c-ff91-4c1d-803c-a50df5e11fa0.png?width=222&height=478)
![](https://cdn.sp-selfservice.com/ml/271124-f-e114d3c9-348b-4ad2-9e6f-3152ed786909.png?width=354&height=766)
![](https://cdn.sp-selfservice.com/ml/271124-f-e114d3c9-348b-4ad2-9e6f-3152ed786909.png?width=222&height=478)
![loader](/help/phones-sims-and-devices/_nuxt/loader.BU3jhCRe.gif)
