How to use notifications on your Apple iPhone 12 Pro Max
You can set your phone to display notifications about missed calls, new messages and appointments in the status bar at the top of the screen.
Press Scheduled Summary.
Press Show Previews.
Press Screen Sharing.
Press Notification Grouping.
