My Apple iPhone 12 Pro Max uses a large amount of mobile data
Press App Store.
Press Mobile Data.
Press Mobile Data Options.
Press Data Mode.
Press Mobile Data.
Press Mobile Data.
Press Scheduled Summary.
Press Show Previews.
Press Screen Sharing.
Press Notification Grouping.
Press General.
Press Background App Refresh.
Press Privacy & Security.
Press Location Services.
