Top queries
Device help
Managing your account
Other ways to get help
Press the music player icon.
Press Playlists.
Press the new playlist icon.
Press the text input field and key in a name for the playlist.
Press Create.
Press Add Music.
Go to the required category and press the add icon next to the required audio file.
Press Done.
Go to the required category or playlist and press the required audio file.
Press the Volume keys to select volume.
Press the song title.
Press the playback queue icon.
