The battery life on my Apple iPhone 12 Pro is short
![](https://cdn.sp-selfservice.com/ml/121124-f-97ff0d21-cdae-49a3-b999-fa949a2a72ce.png?width=354&height=766)
![](https://cdn.sp-selfservice.com/ml/121124-f-97ff0d21-cdae-49a3-b999-fa949a2a72ce.png?width=222&height=478)
![](https://cdn.sp-selfservice.com/ml/121124-f-340afa0d-19f3-4a68-8386-0cc47d062b9b.png?width=354&height=766)
![](https://cdn.sp-selfservice.com/ml/121124-f-340afa0d-19f3-4a68-8386-0cc47d062b9b.png?width=222&height=478)
Press App Store.
![](https://cdn.sp-selfservice.com/ml/121124-f-97392eee-3845-4830-9ff0-c6f93e6ae65c.png?width=354&height=766)
![](https://cdn.sp-selfservice.com/ml/121124-f-97392eee-3845-4830-9ff0-c6f93e6ae65c.png?width=222&height=478)
Press App Store.
![](https://cdn.sp-selfservice.com/ml/121124-f-2649e717-06ed-468a-9de3-ba78ad812ab7.png?width=354&height=766)
![](https://cdn.sp-selfservice.com/ml/121124-f-2649e717-06ed-468a-9de3-ba78ad812ab7.png?width=222&height=478)
![](https://cdn.sp-selfservice.com/ml/121124-f-9834025f-5de3-43eb-bdf1-400acd58cdbd.png?width=354&height=766)
![](https://cdn.sp-selfservice.com/ml/121124-f-9834025f-5de3-43eb-bdf1-400acd58cdbd.png?width=222&height=478)
Press Scheduled Summary.
![](https://cdn.sp-selfservice.com/ml/121124-f-fd53bceb-0739-4090-abe2-aa18a0c5534a.png?width=354&height=766)
![](https://cdn.sp-selfservice.com/ml/121124-f-fd53bceb-0739-4090-abe2-aa18a0c5534a.png?width=222&height=478)
Press Show Previews.
![](https://cdn.sp-selfservice.com/ml/121124-f-719f34e9-2436-4c93-a4e2-11f816b4ca97.png?width=354&height=766)
![](https://cdn.sp-selfservice.com/ml/121124-f-719f34e9-2436-4c93-a4e2-11f816b4ca97.png?width=222&height=478)
Press Screen Sharing.
![](https://cdn.sp-selfservice.com/ml/121124-f-30d984da-cdf0-4487-97db-627a1991faa9.png?width=354&height=766)
![](https://cdn.sp-selfservice.com/ml/121124-f-30d984da-cdf0-4487-97db-627a1991faa9.png?width=222&height=478)
![](https://cdn.sp-selfservice.com/ml/121124-f-0ba391a4-9f5a-427a-9d13-9bce72c26051.png?width=354&height=766)
![](https://cdn.sp-selfservice.com/ml/121124-f-0ba391a4-9f5a-427a-9d13-9bce72c26051.png?width=222&height=478)
Press Notification Grouping.
![](https://cdn.sp-selfservice.com/ml/121124-f-51eb1b75-89a5-4fcc-8565-42d566e56c28.png?width=354&height=766)
![](https://cdn.sp-selfservice.com/ml/121124-f-51eb1b75-89a5-4fcc-8565-42d566e56c28.png?width=222&height=478)
![](https://cdn.sp-selfservice.com/ml/121124-f-154658a6-3782-4b4f-8790-38f7411e8c3f.png?width=354&height=766)
![](https://cdn.sp-selfservice.com/ml/121124-f-154658a6-3782-4b4f-8790-38f7411e8c3f.png?width=222&height=478)
![](https://cdn.sp-selfservice.com/ml/121124-f-98573ccb-43c7-4709-83d1-0d6ba98b2350.png?width=354&height=766)
![](https://cdn.sp-selfservice.com/ml/121124-f-98573ccb-43c7-4709-83d1-0d6ba98b2350.png?width=222&height=478)
Press Mobile Data.
![](https://cdn.sp-selfservice.com/ml/121124-f-bb1992a1-bd68-4f65-9662-c744f8168703.png?width=354&height=766)
![](https://cdn.sp-selfservice.com/ml/121124-f-bb1992a1-bd68-4f65-9662-c744f8168703.png?width=222&height=478)
![](https://cdn.sp-selfservice.com/ml/121124-f-14b8b9f3-557e-4c23-9273-3f70d73fd186.png?width=354&height=766)
![](https://cdn.sp-selfservice.com/ml/121124-f-14b8b9f3-557e-4c23-9273-3f70d73fd186.png?width=222&height=478)
Press Battery.
![](https://cdn.sp-selfservice.com/ml/121124-f-20fff811-7505-4e94-ac60-cf48e2f92989.png?width=354&height=766)
![](https://cdn.sp-selfservice.com/ml/121124-f-20fff811-7505-4e94-ac60-cf48e2f92989.png?width=222&height=478)
![](https://cdn.sp-selfservice.com/ml/121124-f-4675af1f-9404-4bc3-aefd-64d5d486ad8f.png?width=354&height=766)
![](https://cdn.sp-selfservice.com/ml/121124-f-4675af1f-9404-4bc3-aefd-64d5d486ad8f.png?width=222&height=478)
Press General.
![](https://cdn.sp-selfservice.com/ml/121124-f-a4923286-b498-4835-8316-59c255670dda.png?width=354&height=766)
![](https://cdn.sp-selfservice.com/ml/121124-f-a4923286-b498-4835-8316-59c255670dda.png?width=222&height=478)
Press Background App Refresh.
![](https://cdn.sp-selfservice.com/ml/121124-f-0e6fd5d4-157e-4a96-9d04-e92c775b49e2.png?width=354&height=766)
![](https://cdn.sp-selfservice.com/ml/121124-f-0e6fd5d4-157e-4a96-9d04-e92c775b49e2.png?width=222&height=478)
![](https://cdn.sp-selfservice.com/ml/121124-f-09fa0457-38a0-423b-9a61-e888261da62a.png?width=354&height=766)
![](https://cdn.sp-selfservice.com/ml/121124-f-09fa0457-38a0-423b-9a61-e888261da62a.png?width=222&height=478)
![](https://cdn.sp-selfservice.com/ml/121124-f-e11c289a-3af7-4547-9838-eb5f9dcf2b3c.png?width=354&height=766)
![](https://cdn.sp-selfservice.com/ml/121124-f-e11c289a-3af7-4547-9838-eb5f9dcf2b3c.png?width=222&height=478)
Press Privacy & Security.
![](https://cdn.sp-selfservice.com/ml/121124-f-6c2e518f-8e9f-411d-af1f-0e1073724124.png?width=354&height=766)
![](https://cdn.sp-selfservice.com/ml/121124-f-6c2e518f-8e9f-411d-af1f-0e1073724124.png?width=222&height=478)
Press Location Services.
![](https://cdn.sp-selfservice.com/ml/121124-f-c7ff2986-2c4b-4763-a6aa-ff3fc89ae165.png?width=354&height=766)
![](https://cdn.sp-selfservice.com/ml/121124-f-c7ff2986-2c4b-4763-a6aa-ff3fc89ae165.png?width=222&height=478)
![](https://cdn.sp-selfservice.com/ml/121124-f-4a07997f-48c1-40c6-b52d-7e6959b2743f.png?width=354&height=766)
![](https://cdn.sp-selfservice.com/ml/121124-f-4a07997f-48c1-40c6-b52d-7e6959b2743f.png?width=222&height=478)
![](https://cdn.sp-selfservice.com/ml/121124-f-d57f0408-fe69-4263-89de-8b02bc2091df.png?width=354&height=766)
![](https://cdn.sp-selfservice.com/ml/121124-f-d57f0408-fe69-4263-89de-8b02bc2091df.png?width=222&height=478)
![loader](/help/phones-sims-and-devices/_nuxt/loader.BU3jhCRe.gif)
