How to select lock screen settings on your Apple iPhone 11 Pro Max
Press Add.
Press Focus.
You can set your phone to use a specific lock screen with a specific focus mode. See how to select settings for a specific focus mode.
Press the close icon.
Press the delete icon.
Press Delete This Wallpaper.
