My Apple iPhone 11 Pro Max uses a large amount of mobile data
Press App Store.
Press Mobile Data.
Press Mobile Data Options.
Press the indicator next to 'Low Data Mode' to turn the function on or off.
Press Mobile Data.
Press Mobile Data.
Press Scheduled Summary.
Press Show Previews.
Press Screen Sharing.
Press Notification Grouping.
Press General.
Press Background App Refresh.
Press Privacy & Security.
Press Location Services.
