How to turn WiFi Calling on your Apple iPhone 11 Pro Max on or off
When WiFi Calling is turned on, you can make and answer calls using a WiFi network when you're in an area with little or no network coverage. To turn on WiFi Calling, you need to establish a connection to a WiFi network and turn on 4G for voice calls and mobile data.
