How to use widgets on your Apple iPhone 11 Pro
Slide your finger up or down on the screen to see more widgets.
Press and hold anywhere on the screen.
Press Edit.
Press Add Widget.
Press the required widget.
Press Add Widget.
Press Done.
Press Edit.
Press Add Widget.
Press Smart Stack.
Press Add Widget.
Press Done.
Press Done.
Press Edit Stack.
Your phone can control which widgets to display based on factors such as time, GPS position or your activity.
Press Done.
Press Remove Widget.
Press Remove.
Press Done.
