How to turn Wi-Fi Assist on your Apple iPhone 11 Pro on or off
You can set your phone to use mobile data automatically when the connection to the WiFi network is weak. To turn Wi-Fi Assist on or off, you need to turn on mobile data.
Check out nowYou can set your phone to use mobile data automatically when the connection to the WiFi network is weak. To turn Wi-Fi Assist on or off, you need to turn on mobile data.
