The battery life on my Apple iPhone 11 Pro is short
Press App Store.
Press App Store.
Press Scheduled Summary.
Press Show Previews.
Press Screen Sharing.
Press Notification Grouping.
Press Mobile Service.
Press Battery.
Press General.
Press Background App Refresh.
Press Privacy & Security.
Press Location Services.
