My Apple iPad Pro 12.9 (2022) uses a large amount of mobile data
If your tablet uses a large amount of mobile data, there may be several causes of the problem.
Press Mobile Data.
Press Mobile Data.
Press Scheduled Summary.
Press Show Previews.
Press Screen Sharing.
Press Notification Grouping.
Press General.
Press Background App Refresh.
Press Privacy & Security.
Press Location Services.
Press App Store.
