How to turn the SIM PIN on your Apple iPad Pro 11 (2022) on or off
The SIM PIN protects your SIM from unauthorised use if your tablet should get stolen. If the SIM PIN is turned on, it needs to be keyed in when you turn on your tablet.
Check out nowThe SIM PIN protects your SIM from unauthorised use if your tablet should get stolen. If the SIM PIN is turned on, it needs to be keyed in when you turn on your tablet.
