How to use notifications on your Apple iPad Pro 11 (2022)
You can set your tablet to display notifications about new messages and appointments in the status bar at the top of the screen.
Press Scheduled Summary.
Press Show Previews.
Press Screen Sharing.
Press Notification Grouping.
