The battery life on my Apple iPad Air (2019) is short
Press App Store.
Press App Store.
Press Scheduled Summary.
Press Show Previews.
Press Screen Sharing.
Press Notification Grouping.
Press Mobile Data.
Press Battery.
Press General.
Press Background App Refresh.
Press the Home key twice.
Press Privacy & Security.
Press Location Services.
