How to use widgets on your Apple iPad Air 11 (M3) (2025)
Slide your finger up or down on the screen to see more widgets.
Press and hold anywhere on the screen.
Press the required widget.
Press Add Widget.
Press Done.
Press Smart Stack.
Press Add Widget.
Press Done.
Press Done.
Press Edit Stack.
Your tablet can control which widgets to display based on factors such as time, GPS position or your activity.
Press Done.
Press Remove Widget.
Press Remove.
Press and hold anywhere on the home screen.
Press Edit.
Press Add Widget.
Press Add Widget.
Press Done.
