You can use the music player to play audio files you have transferred to your tablet.
Press the music player icon.
Press New Playlist.
Press the text input field and key in a name for the playlist.
Press Create.
Press Add Music.
Go to the required category and press the add icon next to the required audio file.
Press Done.
Go to the required category or playlist and press the required audio file.
Press the Volume keys to select volume.
Press the song title.
Press arrow left to go to the previous audio file.
