How to improve the battery life of your Apple iPad (9th Generation)
Some functions on your tablet use a lot of power and therefore significantly reduce the battery life. You can reduce the power consumption by turning on low power mode.
Check out nowSome functions on your tablet use a lot of power and therefore significantly reduce the battery life. You can reduce the power consumption by turning on low power mode.
